@Nail Grease related to finally changing engine filter, I also finally replaced my cabin air filter. It was just as bad or worse. I don't know if it coincidence but my A/C has a history of the compressor not turning on. A few bangs on the console would sometimes fix it. It got significantly worse this month, and a couple days after changing the cabin air filter the A/C blows only hot air. I am having my local shop replace the compressor only with a Global brand compressor. They suggest the condenser is fine so I can save some money there.
Three questions for you, Sir:
1. Any thoughts on the new cabin air filter causing the A/C to finally die? Or was that likely a coincidence?
2. Any opinions on Global brand compressors
3.; IS it okay to replace only the compressor and not the condenser also. Local shop is trustworthy, helping to save money and seemed confident that the condenser is still good.
Thank you for your insight throughout this post!
Cheers,
Steve
