Hi guys,
I have a 2009 pilot and the fans aren't coming on. Changed all the relays and sensors.
Hi guys,
Relays ✅
Sensor ✅
I believe there is one fuse?
I'd hotwire each fan to a 12 volt battery to check these.
Reactions: PHM
Yes checked the fuse, they used to come on when the cars temp was about halfway.
Just changed the radiator as well , thinking the lack of fans caused it's failure
Miss our 2005 Pilot
Did you replace the sensors with OEM parts?
Have you checked that you fully mated the sensor electrical connector?
