1 - 17 of 17 Posts
Started our 2016 Touring today and soon thereafter got all of the following messages:
Emissions System Problem
Power Steering System (EPS) Problem
Trailer Stability Assist Problem
Hill Start Assist Problem
Vehicle Stability Assist Problem
Keyless Start System Problem
I did do a search but I can't find a similar issue.
Has anybody ran into this scenario? Thanks for any insights you can provide.
It happened to my wife's 2016 EX-L last month. She took it to the dealer and they replaced the camshaft position sensor. All is well now, so far.
Hey ! It happended to me 2 days ago:
I unplugged the negative on the battery and turn the car lights to on position and waited 10 minutes. I replugged the battery and everything was normal again. Today after a cold -30 the same lights came on again. I took the car for a little ride and the lights were gone after. It a weird thing my friend !
I would suspect weak battery. Reserve capacity at lower minimum during extreme cold.
Reactions: Steffo
I had this happen. dealer said it was fuel injectors and it needed to be replaced. Covered under warranty if you are still within time/miles.
Yes replied several times to others.
This happened twice on my 2017 EX-L. It apears to be push button start related. When you push the button, be sure and hold for at least 1 second opposed to a tap. It's never done it again.
Reactions: JGtravelor
Every time I get a warning on my dash I always come to Piloteers for answers which always solve the problems most of which seem to be computer related malfunctions.
I had the Emissions System Warning. A solution said that when you put gas in the tank wait at least 15 seconds before removing the gas nozzle from the tank. I did it and the warning went away months ago. The warning has not returned. I had the Keyless Start system Warning. A solution said always make sure your car is in park before turning off. Hold the foot brake for 30 seconds before turning off the car. Then turn the car back on. That did not work at first so With the car off I held the start button for 30 seconds then I placed my foot on the regular brake and held for 30 seconds. I then held the start button for 30 seconds and the Keyless Start System Warning went away when the car came on. That was a week ago. It has not come back, yet. I believe most of 2016 problems are mere computer related.
Do you have an after market battery? My 17 Pilot EX-L has a Bosch. It is about 3/16 of an inch to short around the positive post causing the terminal connection to be loose. I'm not say this is your problem, but a loose terminal could cause problems. If you discover that it is loose and are unable to tighten, you can buy battery post shims or cut you box lid so the terminal will drop down over the post further. Option one would probably be best.
Today my 2017 pilot touring did a very similar thing out of nowhere. Turned it on and the following lights were on
Power steering
Vehicle stability
Road departure
Transmission and emissions systems
Hill start assist
Break system
Also rear back up camera was not working and the light showing what gear was blinking. It also felt like the car wad just dragging in power and hesitating. Went to auto zone they rested the battery and it was ok and the code pulled up was p0301
Cylinder 1 misfire and also said problem with
The computer system for the anti lock breaks and to change tje fuel injectors. I just don't see how multiple systems would all fail at the same time out of nowhere but maybe I am wrong??? Just curious how many others have run in to this and not sure where to start..
Power steering
Vehicle stability
Road departure
Hill start assist
Break system
Milage?
There will not be a problem with everything that lit up on the screen. Make sure the battery terminals are on tight. The posts on aftermarket batteries will sometimes not extend through the battery box lid far enough, making for loose connections. If this is the case, they sell shims at the parts store.
Font Auto part Metal Fashion accessory Rectangle
If the battery conections doesn't improve things, the misfire code will need to be addressed.
Has the air filter been replaced?
I'd clean the Mass Airflow sensor.
Our 2016 pilot elite had the same thing happen my wife took it to the dealership and he cleaned the front honda emblem which has sensors and it went away for about 2 weeks then returned and it was a faulty injector. It's safe to drive but take it to a dealership it was covered under a warranty or tsb technical service bulletin. Hope this helps
Power steering
Vehicle stability
Road departure
Hill start assist
Break system
Fuel injectors problems. Your dealer knows about it. They paid the whole new injectors when it happenede to me.
1 - 17 of 17 Posts
