Im buying a new engine for my 2009 pilot at the end of the week.
Engine price vary between honda model at local junkward.
Will a cheaper J35Z8 1500$(76k Km)be ok or do I absolutely need a J35Z4 2200$(135k Km)?
The J35Z8 is 700$ cheaper.
There are many variations in J35 engines over the years. You must buy the correct one for your model year, which is the z4. The z8 was installed in the Odyssey.
Rocky is correct
Here is a little more detailed info on the two engines
J35Z4 - VCM
2009-2015 Honda Pilot
Displacement: 3,471 cc (211.8 cu in)
Bore and stroke: 89.0 mm (3.5 in) x 93.0 mm (3.7 in)
Compression: 10.5:1
Power: 250 hp (190 kW) @ 5700 rpm
Torque: 253 lb⋅ft (343 N⋅m) @ 4800 rpm
Valvetrain: 24v SOHC i-VTEC
Fuel control: Multi-point fuel injection; PGM-FI
J35Z8
2011-2017 Honda Odyssey (North America)
Compression: 10.5:1
Power, torque: 248 hp (185 kW) @ 5700 rpm); 250 lb·ft (340 N·m) @ 4800 rpm)
