Hello - I was just check to see if this was a good prices on my 2011 Honda Pilot. Also, there is a bulletin out for it per the shop. My battery died as it was 3 years old as my wife drives it and It would not start. Also, she started hearing a loud noise coming from the engine. This is what the repair shop quoted me and what is going on with it below. What do you think.
$ 69.68 - Intake Manifold gasket set
$ 65.60 - valve cover gasket set
$ 660.00 - adjust valve clearance and cam bolts back out (re torque them)
$ 94.94 - taxes and fees
$ 890.22 - Grand total for other service needed
Well, The battery is one thing. The noise?
Are these dealer prices or a good independent shop prices?
It may not need a valve adjustment.
We need more info on the noise.
Good independent shop prices. They are saying that the cam bolts are loose per the Honda Pilot tech bulletin that is out. The noise used to come on then when the engine warms up they would go away. The sound was coming from the belt area when I would here it. They said they heard it on top and bottom. The other day it sounded louder per my wife. Then she was leaving work and the car would not start. It would only click but the lights came on. We had it towed to the shop. They said that we could drive it until we got it repaired.
