So I was reading this: Testing fuel pump
I have a feeling something similar is going on with mine, but I'm sure it's not related to specifically his issue with timing.
My issue is that the engine takes a little while longer then it should to crank (like 5-10 seconds) and I have intermittent CEL codes showing up. I get a random misfire code for each cylinder bank, a code for all cylinder misfire, and a code for engine fuel too lean.
There is no audible misfire, and the codes do go away. In fact more often then not they aren't showing. I only see them like once every 2 weeks and they go away the same day.
Does this sound like a bad fuel regulator or a bad fuel filter?
I have an 08 Honda Pilot FYI
When did this start? How many miles do you have? When was the timing belt last replaced?
