1 - 20 of 23 Posts
Discussion Starter · #2 ·
Would doing (power washing-water) this cause problems in Honda Pilots ? * ignore the foam in the video
What needs to be "covered"(wrapped) before spraying water in the engine bay ?
Generation 1 Pilot
Generation 2 Pilot
Generation 3 Pilot
2020 Pilot Black Edition
Steam clean my Gen. 3. Disconnect the battery (remove it optionally, so you can clean inside it. Before I steam mine, I vacuum any visible debris, dust, etc. The spray degreaser (purple power brand, is my choice), and steam. Avoid the alternator, and related areas, don’t really need to wrap anything as long as your mildly careful.
Keep in mind, most of the engine bay gets “wet”....to varying degrees from normal driving say during winter or rainy weather anyway...
For my money invested in my Pilot, only will steam my engine bay. Best of luck!
Cool engine. Gunk citrus engine cleaner. Let it sit about 10 mins. The use the jet option on the nozzle. Let it dry then use gunk engine shine. Wipe off excess. Wash the car after to get the grease and degreaser off my paint.
I get a wet rag and wipe down the engine bay after each wash. I’ll probably do a light mist of water every year or so and wipe that.
Would doing (power washing-water) this cause problems in Honda Pilots ? * ignore the foam in the video................What needs to be "covered"(wrapped) before spraying water in the engine bay ?
Generation 1 Pilot
Generation 2 Pilot
Generation 3 Pilot
That is absolutely, positively the last thing I would do to a modern engine with all the electrical connectors and sensors everywhere. You will be amazed what a roll of paper towels, glass cleaner and about 30 minutes of elbow grease will do. I cringed watching that high pressure sprayer in the video. 🤦‍♂️ That's just being lazy and taking unnecessary chances, IMO.
... that's my concerns.... how many different "sensors" is inside a modern day Pilot engine bay....
Disconnecting your battery de-energizes them. Then wiping and being careful where you clean, and you’ll be fine. This is a big reason I like to clean in “12 in x 12 in” areas, if that makes sense that way it forces me to pay extra attention to what I am cleaning. 10 years with my Accord and 1 year with my Pilot and no issues.
How far is pressurized water forced into hundreds of nook/crannies crack/crevices, battery disconnected or not? That doesn't happen with paper towels/glass cleaner/elbow grease.
Really not that far (or better as far as you’d need it to), as you can greatly adjust the pressure. Sure, could someone that’s never used one and has the pressure jacked way up, yea definitely. Keep in mind, atleast when I used my steamer, it’s in addition to the cleaner sprayed (which do note can spray / leak into many nooks and crannies).
Frankly, at the end of the day I’m more worried about the road salt and grime that splashes up into the engine (and the same nooks and crannies), and getting these.
Definitely no short cuts for elbow grease and a good cleaner for sure....also a good detailing brush Has definitely had help really get into tight spots get the crud out.
If it's the underside of the hood that's stopping wheel splash, might want to slow down a little.
I prefer the longer but more controlled method of wiping with a wet rag, maybe some localized degreaser if needed. I control how much water is on the rag and where the wet rag touches.
Discussion Starter · #13 ·
Name brand engine cleaner, and a hose.
No real good reason to do it, but it does not hurt.
Some people talk about not getting water on the electrical parts, but don't worry, they get plenty wet in a hard rain.
Thirty years ago a car magazine did a test and had a low pressure fire hose poor water on to a number of cars engines.
They all started. The water was hi volume low pressure to ensure that the electrics stayed in one piece.
No issues either with washing an engine, however, I would be very cautious of the product you'll be using. As a former Army Blackhawk mechanic I can tell you that the Army has a banned the use of simple green in helicopter cleaning because of one simple reason. It causes corrosion if not rinsed completely. I would be very difficult for you to completely rinse an engine with all the little spaces that water can/will be trapped after washing. While we enjoyed the grease cutting capabilities of simple green it had its side effect on our hydraulic deck and other areas where water will remain after washing.
There are a number of other degreasers out there without the corrosive properties, just pick one and wash your engine. I would also recommend you let water pour out of the hose instead of spraying (with force).
Never in my whole life.
In my mind it would be a close second to this. Yes, this again. It's kind of mesmerizing. :)
Only once in my life (Honda Civic). I only sprayed it with a water hose, normal water pressure, and covered up the stuff I should. The engine looked much nicer. It started to sqeek that I could not resolve for years later. So never again (for me).
2012 Honda Pilot Touring
I try to keep mine clean. I will hit them with some degreaser and then spray off with the hose when the block is cool. I mainly focus on non sensitive areas. This evening I touched up a fair bit of the plastics with some Meguiars Ultimate Black Plastic Restorer. I should have taken a before image.
Reactions: ys1219
Nice. You could eat breakfast off that engine bay. Yeah, too bad there's no before picture but I suspect it would look like most Piloteers' engine bays. :)
1 - 20 of 23 Posts
