If there is play in the inner tie rods then change them, I only had minimal play in the drivers side, so I changed it.
Thank you for the reassuring post! I'd replaced both front (and, rear) sway bar links w/OEMs on my new-2-me '10 & that actually "cured" the clunk...but, I'd ordered bushings at the same time & had been procrastinating installing them due to the degree of difficulty on driver's side. ...gonna take a day & tackle it...with suggested offset wrench to loosen in hopes no sub frame dropping will be required (...gotta keep telling self: patience!! Right?). :29: McThank you everyone for your insight with this fix. I replaced the front bushings today and it fixed the clunking noise. I went with using the 14mm offset wrench and it did the trick. The driver side was a PITA, but it made the pass side that much easier . Like others have said, the key is to be patience with the driver side. Thanks again!
If you have a 2010 model, the placement of the front sway bar bushings is much easier than the 2003-2008 models. I have a 2011 model too and I can see there a lot easier and more room to get to the bolts. Good Luck.Thank you for the reassuring post! I'd replaced both front (and, rear) sway bar links w/OEMs on my new-2-me '10 & that actually "cured" the clunk...but, I'd ordered bushings at the same time & had been procrastinating installing them due to the degree of difficulty on driver's side. ...gonna take a day & tackle it...with suggested offset wrench to loosen in hopes no sub frame dropping will be required (...gotta keep telling self: patience!! Right?). :29: Mc
Even better news -- thanks! ...looking forward to the project...well, almost :wink:If you have a 2010 model, the placement of the front sway bar bushings is much easier than the 2003-2008 models. I have a 2011 model too and I can see there a lot easier and more room to get to the bolts. Good Luck.
Could you explain why he count not recommend any of them? If my mechanic said that it could mean almost anything.....He told me in good conscience he could not recommend any of them.:headshak:
