1 - 2 of 2 Posts
I want to add another screen in the front passenger seat for DVD viewing. WHERE DO I HOOK UP THE CABLE???
Where is the auxillary plug...do I have to remove the DVD player..is it behind it....how???
Help!!!
Bob
Help!!!
Bob
You will have to run a Video RCA plug from the Monitor to the Head Unit Signal Output or DVD Signal Output. I personally would run it to the Head Unit. The RCA cable will have to be cut and the wires separated. These wires have to be spliced into the Head Unit Signal Out wires (B4-Video 2 Out-White/Green Wire & B12-Video 2 Ground-Black/White Wire).
If you want to connect them to the DVD video out instead, you would tie into the DVD Signal Out Wires (C6-Video 1 Out-Blue Wire & C17 Video 1 Out-Pink Wire).
This should help with the Head Unit removal for the wiring.
Here are some grainy photos for the wiring, but they should help.
1 - 2 of 2 Posts
