So I have been battling the amber DRL warning light on the dash for a 2010 Honda Pilot and was hoping for some help. One of my daytime running lights has not been working. It is not the bulb, just one side won't work. I sodered the DRL board and nothing changed. I replaced the DRL module board yesterday and the one light remains out. What else could it be and what am I missing? Thanks in advance!
Have you verified the bulb socket connection is in decent shape (no corrosion, oxidation, broken wiring, contact pin bent too wide, etc.)?
Thank you for the response. I assume this is done by visually seeing if there is a problem with it? Will try it later today.
Yes, perform a visual inspection. If something looks questionable compare it to the working bulb socket.
If you have a volt meter (multimeter set to DC voltage) you can also verify ~12Vdc is present at the socket when the DRL bulb should be on. Perform this measurement with the bulb removed from the socket.
