1 - 8 of 8 Posts
Has anyone figures out how to be able to drive with the gate open in thier Gen 3 without the very loud warning beeping? I had to move a couple 12' boards and had the hatch mostly closed and had to listen to the beeping the entire 3 miles home. The "dismiss" button on the screen did not stop it. Very annoying
Sent from my SM-N950U using Tapatalk
I don't think it's possible. I had the same thing with an extension ladder, annoying / embarrassing to say the least.
Sent from my SM-G960U1 using Tapatalk
Perhaps something from a similar thread might be of some help:
I'm frustrated with this issue too. I frequently need whole sheets of plywood and lumber. Stupid that we aren't able to override the beeping.
Similarly there aren't any places to loop a rope through on the hatchback to tie it down. I end up with the door all the way open, beeping the entire time.
Sent from my SM-G975U using Tapatalk
You might look at this post. Seems like a lot of hassle though!
Yea that does look like a pain and. Ot the fix I was looking for. I would love to find a wiring diagram so I can install a switch to bypass this sensor making the car think the gate is closed. Anyone know where I can find one?
A few posts in other similar threads mentioned that if you open the liftgate manually you can then leave it in an open position and not have it beep. Not sure if anyone has tried that to see if it works.
That is not true. This is what I did to keep it open in the first place. It still beeps
1 - 8 of 8 Posts
