1 - 2 of 2 Posts
Hey there People
Question - replaced driver door window regulator. Bolted it back on, reinserted all plugs ! Need to move the regulator up to align the holes in the door to attach the window.
Problem - it's not working. I hear a click in the control unit - is that normal (also hear the click in the other 3 doors.
Saw a video on YouTube about holding the switch down and turning your key to the #2 position like 3 times to reset the Computer. That's the only thing that I didn't do. Any help would be greatly appreciated
Thank You !!!
Not sure exactly what the inside looks like. Did u make sure both the motor and window were up or down? If one was up and the other was down it might not work correctly. also make sure the window lock on the driver side is off
1 - 2 of 2 Posts
