So since I got my pilot about 3 months ago the automatic down and up feature does not work. I have tried the book fix and the fix from various YouTube videos and it still does not work.
I use my window several times a day pulling in and out of Parking garages and the auto feature would be nice.
Any ideas?
With the ignition on:
  1. Lower your window all the way down and keep holding the switch for 3 seconds.
  2. Raise the window all the way up and keep holing the switch for 3 seconds.
Voilà, reprogrammed. :smile:
Once reprogrammed, remember to push or hold the switch all the way past where you feel a little haptic notch to go all the way to auto mode. Before that is just regular iterated up and down.
That's the first time I've heard that.
Tempted to suggest you pull the battery cable and leave it off for a few minutes. Then reconnect and reprogram.
Discussion Starter #5
I have removed the full switch panel off the door for an hour or so thinking the same thing. It should do the same trick as undoing the battery. Still does not work.
