Would like to install a universal smartphone mount in the space between the center stack and the driver's cowl (to the left of the emergency flasher and VTM buttons). Thinking about four small self-tapping screws to install or drilling holes for small anchor bolts for a 30mm by 38mm mount. Anyone know what's directly behind this area?
Thinking about doing this because I don't think any adhesive will work with the heat/cold cycles. Thoughts?
IIRC when I installed my GTA Car Kit Bluetooth Adapter, that part doesn't have anything critical directly behind it. As long as your screws aren't too long, I think you should be OK.
If fact, I just dug up a video of that installation procedure and cued it to where you get a really good look at the part in question, front and back:
