I have seen this listed as a "problem" several times both here and in CR-V discussions.
From what I can tell after putting 15000 miles on the CR-V and 4000 miles on the Pilot is that Honda has designed the top gear to do what a true "Overdrive" gear should do; Maintain highway speed on level roads.
Both cars do exactly the same thing. Almost any incline or atempt to increase speed with first cause the torque converter to un-lock, then a one gear downshift.
Is there a problem that people are finding besides this (what I would call normal) type of opperation?
N_Jay
While I have labeled this the "down shift virus" in other threads, I really do not think that anything is wrong with our vehicles relating to how Honda intended it to operate. I do think this should have been a little more "engineered" by Honda. My previous 2002 Trailblazer would only downshift in really traumatic situations and cruised at 1900 rpm. The Chevy Impala that Honda has provided me as a rental while the field engineer looks at my vehicle, certainly does not do it. No gasket scrunch or suspension noises either by the way. I personally believe that our vehicles should have had a slight gear change to help the engine overcome the increased wind resistance of the Pilot over the MDX. Also, the MDX is receiving a more powerful engine soon. I also believe there was a serious omission in not giving us the ability to designate fourth gear for cruising and pulling. I am OK with the first downshift, but the second one that sends the RPM's to 3000 is irritating and increases fuel consumption. Pushing the A/C button on hills helps as the parasitic loss from the compressor is eliminated. All of us hope transmission life will not be affected. Good luck - BP
Discussion Starter #3
down shift
These is onbly one shift.
The first RPM increase is the torque converter unlocking.
The shift to 4th takes the engine to about 3000 RPM.
One thing all pilots (don't know about other recent Hondas) need is the OverDrive cut off switch. I hate to smash or be aggressive with the accelerator pedal (never a fan of pedal to the metal culture) when trying to pass a slower car. With a cutoff switch engaged, just give a little gas to go around a slower car--my style of driving. Is there a way, one could force the tranny to stay in 4th?
Discussion Starter #5
Maybe they dont want you driving in 4th?
They gave you a "D3" setting for when you REALY need to use it, and "D" setting for when you don't.
Maybe they know specifically don't want people driving around in "D4" for a good reason?
Could be for durability? Could be not to get them in trouble with the CAFE people? Could be just to piss you off :2:
We, the consumers may never know.
Grade logic control
Hondas have something called "Grade Logic Control". When going uphill/downhill, the transmission will downshift allowing the vehicle to accelerate to the top or slow on the downhill. This is engineered to prevent gear hopping you will find in many vehicles.
