1 - 2 of 2 Posts
So I had to peel back some of the white fabric soundproofing material behind the front door panel to access the metal door skin from the inside. Does anyone know what I can use to get the white soundproofing to adhere to the metal door again? The adhesive that was there felt like dry stretchy foam.
Thank you
Thank you
I'd use this double sided mounting tape for outdoor. This is an inch wide. I'd cut it to 1/2".
1 - 2 of 2 Posts
