41 - 60 of 85 Posts
Hey Guys quick question. This is my first time posting something and as the topic is the dome lights I was wondering if any one knows the bulb name and or size that corresponds to the lights inside the car. I have a 2005 Pilot and I cannot find the size or bulb size anywhere. I'm not sure if I'm looking for the wrong thing or what but if I could get some help that would be awesome. I'm asking because I have two interior lights out that I just noticed today. Thanks guys!
According to kbcarstuff.com the interior dome lights should be "194"
Heres a screenshot of the website. You can search any vehicle and find out what size bulb fit . Text Font Line Screenshot
2014 Pilot LX
California
Ordered the switches from mouser and installed today. The lights work as normal now. Both switches were bad. The only difference is that the new switches do no, "click" when pressed. No complaints though.
My 2007 Pilot has same issue with the Map light with this exception. The passenger light will not come on unless you push it in 2 times and will not stay on. It only stays lit if you hold it in.
Seems like both issues popped up at the same time.
Alexander
Map Lights not working with switch or door
My 2007 Pilot had evolving map light issues over the past couple years. First, the left map light would not work with door open but would work with switch (sometimes). Then the right map light then would work with just door switch (sometimes). Left light then would not work at all. Lastly, the left side started working again with the switch.
So, I just ordered 2 map light switches on Amazon for ~$13 and a map light bulb for $5. I changed out both switches and the left bulb and all is fixed. The circuitry is not intuitive (to me at least) as the bulb seemed to work sometimes but in the end needed to be changed anyway to make work with door and overhead switch. My advice would be to change both switches and bulbs as cost is minimal.
I searched the map light removal on Youtube and found an Acura video that was exactly what I saw and was very helpful.
I just ran into this same problem with my 2008 EX Pilot.
Problem Summary - Bulbs are OK. Driver's side map/dome light would not turn on with door opened. All other courtesy lights would come on including passenger side map light. Also same thing....would not turn on with master switch (lower left side) but all others would. However, driver's side would turn on when lens-switch pushed (door opened or not).
After reading this thread I solved it by taking the assembly down (follow the instructions earlier with the 4 screws) and then taking out the 2 white switches, bending the contacts a slight bit to make them tighter and then re-installed the switches and assembly. Everything is working as normal now. Very easy 20 minute fix.
I did not need to buy any parts and it's working great. Thanks for the information everyone!!
I have nothing more to add technically, but I do want to thank everyone for their contributions. Our 2005 experienced this issue (driver side light only), and I was able to resolve it quickly because of this thread. I'm a bit of a perfectionist and it bugged me every time, so I am happy now. My wife did not seem to mind (this is her primary car) because she said there are enough other lights; her past cars had the typical single dome light. She _is_ happy that I no longer complain about, so we are both happy to have the issue resolved.
What do the white switches look like
Sent from my Nexus 5X using Tapatalk
I'm hoping that will fix my problem because my front dome lights only light when pressed, but the other rear ones light with the door open
Just had mine go out today. I'd like to thank those who posted how to fix this issue. It took 15 minutes to find the tools, take it down, pry the metal contacts apart and reinstall. Works like it should again. :7:
Here are the pics to go with the installation (pics 1- 10).
Last few pics 11 - 13
Excellent description and pics. Just did this for my passenger's side map light.
Once opened up, sometimes the microswitch just needs to be jiggled to work again, because the assembly has been discombobulated by *someone* in the passenger's seat hitting it with disproportionate force. :headslap:
Sometimes it's just a bulb.
A rare retraction, like they say in fancy newspapers :|:
Said passenger side map light continued to go off intermittently, even after my "fix."
The cause? Sometimes it's just a bulb. :|
In this case, according to the owner's manual, a 12v 8w festoon type bulb. The Canadian Tire store I dropped by just before closing only had that size in a 12v 10w, but you know what? Not only does it work fine, but I noticed the very slight increase in brightness made it equal to the driver side map light, whereas it had been slightly dimmer before, which leads me to believe that perhaps, just perhaps, the previous owner had put in a 10w replacement on the driver side, which led to an "imbalance" in wattage in the circuit and that led to the original 8 watt bulb being fed a slight surge which caused it to fail earlier.
I can already hear opposing counsel interjecting,"Objection, your honor; calls for speculation."
My Honda Pilot 2007!!
Front map lights on both sides do not come on when the doors are open. They work when they are pushed, but not when the doors are opened.
05 Pilot.
I took my switches out this past weekend and swapped them side to side and everything works now. Prior to that, my map lights were not coming on when the doors were opened and the driver side map light was the only one that would come on when I pushed the switch. Hopefully its not a temporary fix but we don't drive this suv much so I thought I'd give it a shot.
05 Pilot.
And this past weekend they already started acting up again. So I ordered the switches and put them in 3 days ago. Working fine now!
I haven't taken ours down yet. On our 08 Pilot. The front doors have been 0ut for years, push it, it comes on. I read about wiggling the switch, etc. I was going to try some spray, never took it down.
I order 2 of the switches' for ~ $10 shipped. I know, I know, that's on the expensive side, but it's only $10 though.
I'm installing in a few minutes- I'll get back with what is hopefully a success. Even if I can get them to work by wiggling, I'm replacing- not sending those back. I'll going to put some Di electric grease on the contacts too. Maybe that will help long-term?
* OK, done. glad I had some 'how-to's'
I've been wanting to do this for years- finally got around to it with the order link from one of the threads.
* The only thing I have to add is that if you plug the wire connectors back into the whole unit- you're gong to be disappointed with the results as I was- UNTIL, you screw it back it and the front screw grounds the unit also- thus closing the circuit with the door switch.
All is good - We have light when you open the door!
Thanks Piloteers.
Funny- I'm being soo much better to my Pilots now, when we bought our second one , a minty used 15 LX 4WD a few months ago. NOW, I'm changing transmission fluids, etc.
Before it was only religious oil changes.
Getting this job done is good for what ails you. :)
I just did it. I had had the one on the passenger's side on the fritz for a little while, but when the other one, the one on the driver's side, also gave up the ghost, well that's when the clash of the titans between my OCD and my procrastination finally tipped in favor of the former.
Yeah, I noticed that too the other day when I finally did it. There was an uh-oh-what-have-I broken-now moment. Good of you to add that info to this thread too, to help others avoid that heart-sinking feeling.
The only thing I'd add to that fine and helpful thread (if I only could
141204
) is that if you try to test it before screwing the module back in, it probably won't work right, as I assume one or more of those screws provide a necessary ground.
41 - 60 of 85 Posts
