1 - 17 of 17 Posts
I just noticed this today as I was walking towards my car from behind in a parking lot. There's this "ring" onto which you can hook something right underneath the bumper on the leftside, but I didn't find one on the right side. I took a look underneath on both sides and seems the holes are already drilled on the rightside, but that ring is not attached at all.
I don't have a towing package installed, is that why I only have one or am I just missing one? If the former, I'm rather curious as to why there's even one to begin with or if the latter, should the dealer be install the missing one for me? As well, what would those hooks be used for normally? Thanks.
Tow Ring?
I think you will find the ony real purpose for that ring is to provide a safe and secure point that can be used to secure the vehicle while it is being transported.
Yes, it can also be used as a tow ring, and every pilot I have seen has just the one.
Discussion Starter #3
tibbitts said:
Tow Ring?
Ahhh, I see. Cool, thanks.
Yep, one big ring on the left, rear corner and a smaller one in front. They are tow hooks which can be used for "light recovery" if you are stuck off-road.
2003 Owner's Manual
From page 266 Off-Highway Driving Guidelines
If You Get Stuck
"If you are unable to free yourself, you will need to be pulled out by another vehicle. Your Pilot is equipped with front and rear tow hooks designed for this purpose."
It just doesn't specifically say there's only one in the front and one in the back...:(
My Pilot doesn't have the rear tow hook. That's not to say that it's missing; actually, it's on a shelf in the garage. You have to remove it to install the tow hitch.
RipRock,how in the world Pilots have rings while they have no fingers???:rolleyes: :rolleyes: :rolleyes:
Discussion Starter #8
Re: Re: Do your Pilots have only one ring as well?
Well, there are some rings used out there which aren't meant to go on any fingers at all-it's meant for another appendage :D
I have 2 tow rings... one with a diamond and one without.
:rolleyes:
Re: Re: Re: Do your Pilots have only one ring as well?
YOu know that I was just teasing.My RedRock has only 1 ring on its rear as well
Discussion Starter #11
Re: Re: Re: Re: Do your Pilots have only one ring as well?
Oh, I know, I know, that's why I put that big smiley at the end.
You mean the nose, right??? ;)
Not gonna take any chances with other pictures! :14: :p
My Honda CRX has only one ring too.
I was told that while those rings can certainly be used for the purpose stated in the manual, they are actually installed on the vehicle for tie down points during transportation between the factory and wherever they're shipped to via truck or ship.
1 - 17 of 17 Posts
