Post is missing.
I did all 4 rotors and pads last night. It was the first time doing a brake job (excluding doing pads once on CRV). Took my time, and finished in an unimpressive 4 hours. Used silicone grease for the caliper pins, brake quiet on the back of the pads, a dab of anti-sieze on the pad tab like part that touches the caliper to help slide it in. Besides that, rotors, pads and tools. Sledge hammer, lugnut wrench, 3/8 breaker bar, 19mm, 17mm, 12mm sockets and combo wrenches, and a drill for the pesky rotor screws.
This was my procedure for front/rear brakes:
1) Remove tire
2) Remove caliper bolts (front 17mm, rear 12mm) and swing caliper out of the way making sure it has proper support (I used a bungee cord)
3) Remove the pads (and take note of their wear and where the wear indicator was located)
4) Remove the caliper bracket (front 19mm, rear 17mm)
5) Remove the rotor screws (I drilled them out, since it was fast and I didn't plan to put them back in)
6) Wack the rotor with a sledge hammer every which way till you get the darn thing out (NOTE: for rear brakes, make sure the emergency brake is OFF prior to this)
7) Clean new rotor with brake clean and slide on
8) Lube caliper pins with silicone grease or other grease, make sure the booties go back on properly
9) install caliper bracket
10) use clamp to compress caliper cylinder (take note of level of brake fluid in reservoir under hood, it can overflow! use baster to remove if needed)
11) Install pads, put brake quiet on back after installed
12) Slide caliper on, and install
13) Re-Install Tire
A couple of links I found useful:
Honda Pilot Front Brake Pads Replacement Guide - 2009 To 2015 Model Years - Picture Illustrated Automotive Maintenance DIY Instructions
