1 - 2 of 2 Posts
I need some advice on what could possibly be wrong. We had some front bumper work done on a 2010 Pilot. They had to replace the parking sensor and fog lamp as well. When we got the car back, the daytime running light on the passenger side was illuminated, but in a lower spot than the driver's side. We took it back to the shop that did the work and they said they could have it fixed in 15 minutes. After a bit they said couldn't figure out what the issue was so the hooked it up to a computer (something under the steering wheel I assume, because my mat was out of place) and now my VSA, ABS and VSA warning (triangle with exclamation point) indicators are on. What could possibly be the issue? The shop is bringing in their mobile mechanic to take a look at it, but I want to be prepared, so that they don't take advantage of someone who doesn't know a ton about cars. Thank you in advance for any input you have.
I believe the DRL and high beam bulb are the same which means they probably got the two swapped when they were working on the bumper. Should be a very easy fix by switching bulbs to the proper location. As for the warning lamps. Not sure what to say here other than have a qualified tech look at it. The people that did the bumper work are defiantly in over their head. Good luck.
1 - 2 of 2 Posts
