1 - 11 of 11 Posts
I suddenly notice the D3 light on when driving. When this happen, transmission doesn’t select above 3. When I turn off the engine, and turn on the engine , on shifting to D the D3 light turns on again. When I press the D3 button on the shifter the light goes off and turns on after some seconds. Sometimes the light stays and sometimes it flicks .
Pls, anyone with advise on what’s wrong or how I can fix it?
Sorry, I didn't finish my last post. If you visit an auto parts store, they should read the code for you at no charge. Just make a note of what the code is. You don't have to buy a code reader unless you want one (I like have one handy though).
If you look up those codes, they relate to the o2 sensor, evap system and cat system. Not sure what any of these have to do with 4h gear. Did the CEL recently come on when the d3 issue started? Have you ever had the codes cleared? I am wondering if you be better off clearing the code and then see what comes back.
Thanks for your input so far.
I found the issue. The D3 button on the shifter got stuck making the light to flash.
1 - 11 of 11 Posts
