Recently pick up a 2013 EX, 112k miles, not muzzled. The other nigh CEL came on blinking. Had all four issues in the title, oil wasn't touching the dipstick. Put a new spark plug in as the old one was badly coated with carbon. Swapped a coil from a dead Ody I still have (same engine), and put a quart of oil in.
Trying to figure out what the true issue may be. Spoke to a Honda dealership and he looked up my VIN, saw it was last at a dealership in NY where they listed timing belt, valve lash, piston rings, and cyl 1 misfires. No service was performed. The Honda guy said #1 cause for oil consumption on these engines is the valve lash, and said to get that done. But it seems to me it's a lot of oil lost over seating of the valve.
Could need of a valve adjustment really cause that much oil loss? I thought maybe the bad coil (no spark) could cause fouling/oil loss, but the code should have come on early. Has anyone seen that much loss and it's not rings? I'll check the PCV to be safe but seems to be cyl 1 specific. I have an aftermarket warranty that expires soon so need to seed what can be done, and who would do it (not many interested in doing piston rings). Will be getting it muzzled soon as I can and maybe put some engine treatment in the case before the next oil change. Thanks for any input
