1 - 11 of 11 Posts
2009 Pilot 170k. Time to replace the CV joints / axles as there is loud clicking (on hard turns), and pulling to that side.. Some questions about this job:
When did yours go out? (miles)
Are aftermarket parts OK? or should I go OEM Honda? Some kits include hubs (with bearings) - do you recommend this?
How much did it cost? I called a local shop who said 2.6 hours ($327) for both sides of front. Plus parts
Discussion Starter · #2 ·
Let me know what you think! My quotes so far:
Honda dealer $1070 both, $550 if just one is needed
small shop - $660 total both sides (trakmotive axles)
Pep boys: $327 (labor) both sides + I bring parts (Cardone Axles $62 each @ amazon)
Don't waste your time with Cardone, better off with bad oem then those. We have so much trouble with aftermarket, that I won't put anything but oem in pilot, odyssey, ridgeline, or v6 accord.
Thanks - sounds like aftermarket are RISKY! anyone know where to get best price on honda parts?
I replaced my own on my 2009. I replaced the struts, brakes, rotors, and bearings while I had it torn apart. The vehicle had 195,000 miles on it.
The only issue I had with the CV shafts was the passenger side. I pulled the shaft apart and left the cup attached to the Transmission. I had to make a slide hammer out of a set of vice grips to get it off,
I messed up both ABS speed sensors as well. Those had to be replaced.
Based on what you post, I listen. (he is a current auto tech). Thanks
Good info...did you go with Honda or aftermarket axles and struts? I may do struts also. I have a mechanic friend who might help me do this. Did you use the assembled struts? How is everything holding up?
2011 Pilot EX-L
Honda driveshafts only for me. BTW, they just jacked up ther prices on them out of the blue. I was about to buy a LHS one for me, and it went from $300 (Canadian) to $400 for me just about overnight.
Never really had good luck with any aftermarket shafts on any of my other vehicles (except for Land Rover Defender).
Super Moderator
OEM axles for the best results. Takes a variable out of the search for old or new vibration issues. Less expensive aftermarket axles could work out especially if there is plans for short term ownership.
1 - 11 of 11 Posts
