Hi everyone.
I hope that maybe someone can shed some light on this weird occurrence.
I have a 2011 Pilot Touring AWD. 142k miles. Timing belt changed 1k miles ago and alternator changed last Thursday. All was running as it should except for a leaking Spool valve. I changed both gaskets on the spool valve and went for a drive. After about a mile of driving a bunch of lights started coming on. The ABS, VSA, Check Brake System would come on and turn off. The VTM-4 light would come on and turn off only when restarting the car.
I took the car home and went to check the connections of the harness. It all seemed to be ok. I unhooked the battery for an hour just to make sure everything was reset. I know, I know, overkill
Went for another drive and the car ran great and I accelerated a little aggressively and slowed down and then the ABS, VSA, Check Brake System lights came on again. I would accelerate and the lights would go off. They would stay on only for a second or two. I could replicate this often.
Thought that the battery might be bad or the alternator also. I went to AZ to have them check the battery and the alternator. All checked out well. While there were no lights on at this time, I asked them to check for any codes. There were none.
I left AZ and as soon as I got out of the parking lot, the VTM-4, VSA, Check VSA lights came on and stayed on. The Check VSA light would change to Check Transmission light and back and forth.
Seeing that these lights stayed upon, I returned to AZ and again checked for codes. Again, nothing.
Help!
Thanks in advance everyone.
Help!
