1 - 12 of 12 Posts
My 2003 Honda pilot has finally died @ 313,000 miles & I'm trying to revive it. I did some investigation (during a blizzard) & couldn't find the problem, so I took it to the shop & they couldn't figure it out either. So far I know:
-no bad dash lights or engine codes
-battery & connections are good
-full tank of gas
-has fairly good compression
-cranks at normal speed but no spark
-replaced main relay
-the roof or windshield has been leaking & the front carpet is wet & the technician said the carpet is energized.............???
Any thoughts on where to go from here would be appreciated. We all seem to be stumped & I would like to get the car fixed as opposed to buying a new one.
Thanks!
Any chance you're using an aftermarket key?
https://www.piloteers.org/threads/aw-nuts-cranks-but-doesnt-turn-over.118505/#post-1221721
For the wet floorboard, start by locating and unclogging your center nipple and dangling hose. :)
A couple times when it had been raining or snow was melting on the roof of my car there was water dripping by the rear view mirror...
It died after it warmed up & drove to the top of the driveway, 100 yards. (weather was in the single digits in the ski town I'm living in) It was missing & not full power going up the driveway until it died on the road.
It has good compression, just no spark. Turns of the mechanic found .5 volts of electricity in the carpet. Bringing it home to investigate it further.
Yep, that's where I'm at.... Now the challenge of tracing where the short is & if it has fried anything else in the system, like the computer. Any suggestions on best way to trace it? I was planning on ripping out the front carpet & drying everything out for starters... Thanks Tanner!
Removing the carpet to dry / change, may locate a wire(s) or a loose connector under the wet carpet (that would be an easy solution). The carpet will have to be addressed anyway.
It could also be a shorted wire rubbing against a metal frame piece, like under the dash or in the console, that has the frame bolted down to where the wet carpet is touching it (thus transferring the voltage).
Discussion Starter · #12 ·
Thanks Tanner, I appreciate the advice. Its not easy working on & drying out a wet car in the winter in a ski town without a garage. So until it warms up or I find a garage I can use... I'm in the market for a new vehicle. When I solve it, I will be sure to post the answer ?
1 - 12 of 12 Posts
