1 - 2 of 2 Posts
Hi. I have a Honda Pilot 2004 4wd.
And i find leak in AC system.
The valve for refueling the air conditioner flows on the low pressure pipe.
Question. Is it enough to change the blue valve cover? Or do I need to completely change the hose with valve and cap? Thank you in advance.
Fuel line Auto part Windshield Automotive fuel system Engine
Replace the valve core. The cap does not hold pressure. But as this pipe is notorious for leaking at the connections, make sure all 3x do not leak.
Reactions: EnderMbs
1 - 2 of 2 Posts
