1 - 20 of 20 Posts
Super Moderator
Opinions on the attached picture of OEM thermostat cover. Scraped off all of crusty dried coolant that may have leaked out over the years. Replacement OEM thermostat cover $69 versus Gates $12 from Rock Auto. OEM thermostat $47 versus Gates $18. Big difference in the prices. Anyone have experience with non-OEM?
Metal
2020 Pilot Black Edition
View attachment 140485 View attachment 140486
Is this the old part? If you could hit it a bit with a metal brush you should reuse....looks in prett solid condition (aside the surface corrosion)
Super Moderator
Yup that’s the old thermostat cover. After scraping off the crusty dried coolant I think the pitting is too deep and could leak even with a new hose/clamp. I’ve seen some auto repair shops coat the pitted thermostat cover with some white plumbing sealant.
Heck, might be worth a shot with using the sealant for say a few days...see if it does the trick. If not, revisit your options?
One has to wonder what temperature range (low to high) that sealant stuff is good for. I wouldn't want to revisit the job later at what is usually an inconvenient time. I'd just get the Gates and be done with it.
Super Moderator
Agreed. Macgyver would say the right plumbing sealant could work but I really like to get the job done ✅ once and done especially where the thermostat resides down in the engine bay. The Gates parts are listed as direct OEM replacement. and the price difference is incredible.
Yes, correct...to clarify sealant could theoretically work but yet at best it would be a bandaid job....and for the $30 for both Gates parts, worth trying out IMO. Maybe will be a worth aftermarket brand to OEM?
Save your money. This part still has plenty of life in it. Soak it in a cup of CLR, rinse thoroughly.
Permatex makes a variety of silicones for different aplications. This is what I'd use.
140493
I used high heat Black Permatex in place of Honda Bond on a spool job. That was 50k miles ago and still holding. They make good stuff.
Super Moderator
Great I forgot about Permatex! I know I got some in the garage somewhere. When running gas lines or sewer lines the plumbers luv that pipe joint compound probably for the similar reasons.
I have seen worse being used .. Grab some Permatex like others stated and run with it .. a wire brush could clean it up a little more but it's just a cover.
Reactions: aggrex
Keep that in the trunk for emergencies ...approved by Macgyver
Ya, maybe to good. A nightmare when you need to get it cleaned off if you had to replace a thermostat.
Reactions: aggrex
Super Moderator
Discussion Starter · #16 ·
Looks like that corroded thermostat housing may have been leaking or soon to burst. The Pilot TLC continues...
Wood Rock
So I didn't look to see like you did, but when I changed my radiator last winter, I also changed the upper and lower hoses as well as the thermostat, operating in accordance with something between the Precautionary Principle and Murphy's Law.
Reactions: aggrex
Super Moderator
Discussion Starter · #19 ·
Honda dealer did the TB in 2014. Went to Honda parts to buy Honda special sauce coolant and the parts guy said since the coolant is green >>> use Prestone :p
Auto part Bumper Tire Automotive wheel system Wheel
FYI: the radiator support has been treated for rust and looks wonderful.
Motor vehicle Auto part Vehicle Engine Tire
Honda dealer did the TB in 2014. Went to Honda parts to buy Honda special sauce coolant and the parts guy said since the coolant is green >>> use Prestone :p View attachment 140604
Best put the cap on. You will let out your green goblin!
140606
My 17 is already green!
Reactions: aggrex
1 - 20 of 20 Posts
