1 - 1 of 1 Posts
Hello Everyone,
Both fan of My 2006 Honda Pilot /90kmiles do not turn on. In the purpose of solving this issue, I made a couple of test tests: fuse, relay, fan motor... they all work correctly. Then I unplug the cooling temperature switches so that I could use a paper click to short circuit it ( to give the ground signal directly); but as soon as I unplug the two switches, the fans turn on if the ignition is on.
So I get lost, I am asking where the coolant circuit find this ground signal, which is supposed to come from the ECT sensor.
Thanks for taking time to read it and Any help will be very appreciated.
1 - 1 of 1 Posts
