41 - 60 of 61 Posts
· Registered
Home of the 309k 2012 V6 Honda Crosstour
Discussion Starter · #45 ·
Just given this vehicle after maintenancing it 9 months ago.
149868
· Registered
Congrats:
  1. Water pumps are known to weep. Just keep an eye on the overflow tank.
  2. Pre 2013 models did not require full synthetic oil and had smaller oil passages for the timing chain. Some have had stretched chains. Looks like you are extremely low miles so stick with full synthetic and keep the level topped up.
  3. The PCV orifice (it's not a valve) was updated in 2013 to have a larger hole so the gases would slow down and let the solids drop out more effectively. Recommend popping the PCV off as well and drilling out the holes to prevent this from ever being a problem.
  4. The transmission has the worst tuning for anything other than acceleration from a stop. Fresh Dex VI will help but mine still slams a downshift at a roundabout if I don't get it just right.
  5. Waveplates (3-5-R) in the transmission were known failure points, I don't think it was a recall so read up on that.
Otherwise, they ride great and are huge, even compared to a Pilot. Excellent highway vehicle and excellent seat comfort for my big and tall arse. Good mileage. Happy motoring.
Reactions: Nail Grease
· Registered
Discussion Starter · #47 ·
Congrats:
Ty for info. Was hardly driven 34k miles.
This is what I did 9 months ago.
  • AC Delco Air Filter # A3083C
  • Rotella Gas Truck 5w30 5.5qt
  • Mobil1 oil filter M1-113A
  • 2 x D&F, 4.5 quart Amalie Universal Synthetic ATF
  • AC Delco PSF 3qts # 10-5073 (GM# 19329448 32oz or 450 16z)
  • Front Brake pads
  • Dot 3 Brake fluid flush
  • Radiator Flush with Distilled, 1.75 galllons DexCool
Reactions: cintocrunch
· Premium Member
Congrats:
Is that one of the engines that has timing chain problems caused by inadequate lubrication?
· Registered
Discussion Starter · #49 ·
Need a set of tires. Dry rotted Bridgestones. 🤦‍♂️
· Registered
Discussion Starter · #51 ·
I just put a set of Continental Tru contact on the Wife's Volvo. Excellent tire in dry, wet and snow
Ty. Not any of my favorite tires available in 255 65 18.
· Registered
Yup, the early LLT had the combination of not requiring synthetic and smaller oiling ports for the chain.
That's the size on my Traverse. I got the Michelin X LT A/S, the Costco branded version of the Defender LTX. Probably more than you want to spend but they were great driving to Orlando and Cincinnati and are great in heavy rain.
· Registered
Discussion Starter · #54 ·
.3 The PCV orifice (it's not a valve) was updated in 2013 to have a larger hole so the gases would slow down and let the solids drop out more effectively. Recommend popping the PCV off as well and drilling out the holes to prevent this from ever being a problem.
Just checking on this PCV and found that it has 2, a left and right. I assume it's the right side metal one that's a concern. Need to drill all 3 holes out?
149914
149915
· Registered
View attachment 149914 View attachment 149915
See the thread below. I would say size shouldn't really be a limiting factor, as long as a vacuum can still be pulled through it the system will work fine (and a vacuum will certainly be pulled no matter what).
· Registered
Discussion Starter · #56 ·
Wow! Drilling a PCV, lol. Will be doing this. Thanks for the link.
· Registered
Slow the gases down so the suspended solids can settle out and not get sucked into the intake. Makes sense to this idjit.
· Registered
Discussion Starter · #58 ·
Since inheriting this 2010 Acadia, might as well drive it, right? After just a couple of three thousand miles, the struts blew out all the hydraulic fluid and got the classic knocking sound driving on rough roads. Seems time was the enemy more than mileage. Anyway, slapped on these new KYBs instead of Gabriel or Monroe. Works great on the Honda Crosstour.
¯\(ツ)
Automotive tire Coil spring Valve Gas Plumbing valve
Automotive tire White Light Coil Plumbing valve
· Registered
Discussion Starter · #60 ·
41 - 60 of 61 Posts
