1 - 2 of 2 Posts
Vehicle in limp mode even after I clear codes. Newer spark plugs and #1 is a little wet, oily. Help!!!
I haven't had to mess with plugs (or coil packs) on my 2009 yet (under 90k miles), but since you've seen the #1plug, if I were you I would mark & swap the Coil 1 pack to another plug and see if the problem moves with that coil pack, If the problem moves with the coil pack then replace that pack.
1 - 2 of 2 Posts
