I would say replace the O2 sensors because this affects air/fuel mixture, but your note says your oil is milky? That is usually caused by coolant mixing in the oil.
Sorry, that was notes of things to check, thought it wasI would say replace the O2 sensors because this affects air/fuel mixture, but your note says your oil is milky? That is usually caused by coolant mixing in the oil.
After checking dipstick after getting it home a few hours later the oil was normal color, it was a flashlight inspection on the side of the road thoughSorry, that was notes of things to check, thought it was
If I may weigh in here, all these your present codes?Died and coasted getting up to speed getting on interstate @3500 4000 rpm. View attachment 163673
These codes were up and I cleared them trying to reset stuff on the side of interstate 57, the 02 is always there but the lean after going through water and changing plugs and drying upper plenum, it triggers the vtm code of powertrain failure. The p1456 code and the cmp sensor and misfire happened on 57
