1 - 1 of 1 Posts
Every one, while going through a construction zone my CMBS system went crazy with all sorts of alerts before just calling it quits and throwing an error permanently.
After searching the net I found others that had the problem and it’s because when the system is over worked “too busy” it throws an error (2853-92).
The only way to fix is to take to dealer to clear the code so it “reboots” per se.
Anyways I did that per another forum and now all is good.
But I wanted to ask if anyone has experience with a good scanner that also erases codes for other components like CMBS versus just engine performance. Want to be able to just do at home versus taking it in.
I have a 2016 Pilot, 2016 Accord, and 2018 CRV is that matters.
1 - 1 of 1 Posts
