Theres anyone knows how to fix clunking noise on front wheels when start up the car, turn left and back up, because I already check the ball joint, sway bar, and tie rod end they are still intact and solid, no play on it. 2016 pilot and i have 100km already
I’m at 90k on my 2016 exl and I have the same noise. I have not had honda look at it but I did have another mechanic check it out and he couldn’t find anything.
Everything in the front end is tight.
Sorry, I know this doesn’t answer your question. If I do find out anything I will post it.
Did they try to check the wheel bearing strut or mount strut?
Yes checked everything including motor mounts.
As the original poster mentioned. It’s only when I go in reverse.
Thanks Ddx77
You are welcome. But like I said not sure how much help I’ve been.
Bringing it to Honda is really what I need to do. I just hate to pay for troubleshooting.
My wife actually uses the car, I just have it maintained for her. I had Honda do the 90k maintenance last weekend. Although I’ve driven it, I didn’t think of checking for the noise afterwards. In hopes maybe something they did helped it?
Maybe just wishful thinking. I’ll check for the noise this weekend.
Drew
Thanks Ddx77
