Noticed the last couple of days that the climate control system is shutting itself off in my EX-L. My wife had mentioned it, and then today when we took it to the dealer for our 3000 mile oil change, sure enough, I looked down, and it was just off. I turned the temp knob and nothing happened. Then after pushing the fan + button, and then the next time it happened, the AUTO button, it comes right back on. Anyone else with this? Otherwise the system doesn't show any other problems.
I am confused (It does not take much)
So the system is on when you shut the vehicle off?
When you start the Pilot back up, the climate controls are now off? Or is it just shutting off when you are driving?
It should be set on it's last setting when you start her back up again, and it should be on.
rob
Discussion Starter #3
gopilot,
This happens while driving down the road. One minute it is on, the next it's off, the screen is blank. Very strange. I'm going to call my dealer after I see it happen again but I thought I'd post here to see if anyone else had this issue.
Thanks!
