Clicking Noise from Center Console
It is located on the Drivers side of the console. I was able to remove mine, disassemble it and grease it and clean the contacts on the motor and it works fine now. I removed the side panel of the console after removed the back cover which has the AC control and ducts, The side panel is attached with a couple of screws and the rest are spring clips. The screws are hidden behind other panels so there is a proper order to the whole disassembly. If you're not mechanically inclined, then it might not be a good idea to tackle this yourself. I couldn't find a youtube video for the 2nd gen, but there is one for the first gen Pilot console disassembly which is very similar. View attachment 114049 .
The pic has the part number on it. It was like $45 at dealer or $20ish on RockAuto if i remember correctly. However, they are fairly easy to disassemble and put back together. I broke a couple of the tabs, but the mounting screws also hold the unit together so its been working fine now for about a month.
The font mixer is basically the same but easier to access from the drivers side. 4 screws and an electrical connector. The front mixer has a double action arm which took a bit of creative thinking to figure out. If you’re not mechanical, I wouldn’t attempt it because if you get it wrong, you’ll probably break it.Clicking Noise from Center Console
I have a 2011 Honda Pilot and it makes the the center console noise …. Yet I figured out how to fix …. Once it makes the noise …. Just raise the driver temperature all the way to HI and then noise goes away …. Then after noise goes away lower the driver side temperature control back to Lo …. Noise is gone !I have a 2009 EX-L 4WD and have recently inherited a cliking noise from under the center console, it lasts for roughly 15 to 20 seconds then goes away, doesn't matter what is on and doesn't seem to cause any other issues...any ideas? Thanks in advance.
