1 - 2 of 2 Posts
Do NOT pull of the rubber like I did in the photo. It is difficult to get back on!!!
Clean out your weep drain holes at the bottom of the door, there are 3 holes in each door.
IF you do pull ioff the rubber from the orange tab, loop a thick wire around the orange head about 180 degrees (like a "U"), leave one side open so it can be removed after the rubber is back on. Use the loop to hold the head in position while you work the rubber back on, half at a time. Top first. Then rotate loop 180, do the bottom.
142347
I've also had great luck with a healthy application of the Krown rustproofing treatment every fall. Night and day better on rust in upstate NY vs. my untreated Honda/Acura vehicles.
1 - 2 of 2 Posts
