codes read that all the cylinders are misfiring. this is not the case. I had a new motor put in and the light came on after a day. I noticed when the VTM-4 light comes on I can feel the car bog down just a bit. I drive it a lot and the lights are always on. Someone said I might need a new computer. We tried to reset it but it still comes back on..
Does your scanner read Honda specific codes? The Honda specific codes could provide useful diagnostic information.
Try taking off the pcv valve and clean. I had a similar problem with engine light coming on and vcm light too. Ended up just being up being little piece of carbon holding the pcv valve open....worth a try and doesn’t take long either. Good luck
Clean the EGR passages in the intake manifold. This is a common problem in older Pilots with high miles. The passages get clogged with carbon and cause random misfires. This, in turn, causes the VTM dash indicator to light. Clean the passages, check the function of the EGR valve itself, and replace the PCV valve (cheap). If you can't DIY, have your mech do it.
^^^What he said. Here's a helpful video.
