Since I've been having charging problems and I narrowed it down to the alternator I figured I'd organize everything I documented and written down and put together a guide on diagnosing the charging system. Charging issues seem to be a common problem around here and these cars are a little different being that they turn the alternator on and off through ELD (electrical load detection). I'll try to make this as easy but as complete as possible and continue to edit with any suggestions. I’ve gathered most of this information from all over the place and verified this on my 2003. I can't confirm all this on the newer Gen1 models though. I want this to be an easy to access/understandable way to diagnose these cars. Maybe we can sticky this as well.
Step 1: Check your battery posts and terminal clamps.
Step 2: Charge and test your battery with a battery tester
Step 3: Check your main fuse in the fusebox under the hood
Step 4: Check your drive belt
Step 5: Check all engine compartment grounds (common issue)
Step 6: Check alternator power wire
Step 7: Check alternator bolts are secure
Step 8: Voltage drop test (Multimeter required)
- Clean any corrosion on the posts (this can affect charging)
- Check that the clamps are snug and secure. Loose clamps will result in a poor connection
- Check the cables for fraying and damage. If they're damaged, you need to replace them before anything else.
- There are some affordable testers out there as well as many auto part stores will charge and test it for you for free if you take it to them. This will tell you the state of charge as well as state of health
- State of charge is the current charge of the battery
- State of health takes into account the overall health of the battery by comparing the specified cold cranking amps with the actual measured cold cranking amps, reserve capacity, and charge acceptance
- This is a 120amp fuse. If it's blown it cuts off the alternator positive to the battery and the car will not charge. If blown, check why it’s blown, don't just replace.
- A simple continuity test across the left and right side of the fuse will verify it is still good.
- Check for the following and replace if needed:
- Intact
- No apparent glazing
- Slipping
- Proper Tension: If poor tension; check/replace your tensioner
- Blue circle in the image below is your alternator pulley and red circle is your tensioner
- There are three main grounds that are all known to oxidize/split and lose connection in these cars. Clean/replace as necessary.
- Engine to Body (Green traced in image below)
- Body to Negative Battery Terminal (Blue traced in image below)
- Battery Negative Terminal to Transmission (Red traced in image below)
- On the back of the alternator there is a single threaded post (B) that has a wire that supplies the positive charging voltage. This goes from the alternator to the fuse box under the hood where we previously checked the 120 amp fuse. This cable is traced in yellow in the image below. From the fuse box it goes to the positive battery post. This cable is traced in purple. Check all these connections/wires for damage/fraying. Replace as necessary.
- This is a simple check to verify the alternator is not loose on the bracket/engine.
- The alternator has three bolts circled in red below. One long bolt on the bottom and two on top (one for engine, one for bracket). Give these a quick check to verify they are snug. The alternator grounds through the engine and requires a secure connection.
- Using a mutlimeter perform a voltage drop test across the negative and power sides from the alternator to the battery.
- I recommend following Chris Fix's guide starting at 4:30. Disregard his comments about charging voltage being 14.2-14.7V. Honda uses ELD (electrical load detection) to detect load and shuts off the alternator when not necessary to save fuel, so you will not always see 14+ V and this is normal. We will look into this at a later step.
