1 - 19 of 19 Posts
Has anyone ever successfully changed out the driver side headlight bulb without removing the bumper? I can just get the passenger side on and off by loosening the wiper fluid well but the driver side eludes me. I've taken off the air intake and considered going through the wheel well. Nothing. If you did, how did you accomplish it?
according to the owners manual, You only need to remove the bumper to replace the headlight.
on the drivers side remove the air intake.
133256
removed the damn battery , intake and find someone with small hands ..if not unplug the bulb first then you can twist it loose with your fingers ..after cursing and giving your thoughts on Honda's products ..install is in the reverse order
I have big hands and I was able to do it by just removing the air intake snorkel. I followed this video:
Intake duct comes off. Remove the hold-down bolts for the battery, and you can move it back slightly to make just enough room.
Author's note: I have "radio announcer's hands" -- wee paws for station identification, and generally don't have trouble with such things. :D
So I have a HID system and projectors installed which I think makes this a bit trickier. Is there a way to remove the bottom half of the snorkel? It looks like its a separate piece from the airbox but I can't seem to separate the two.
Projectors on a 2nd gen? Must look nice got pics ?
Discussion Starter · #10 · (Edited)
I finally got it done. In the end, I had to remove the battery like Tahoefever suggested, unplugged all the wiring there for the HID system, tell myself to man up, crammed my arm in there, and used my fingertips to finesse it out. Even then I had to work it for a solid 15 Minutes to get the igniter off.
The projectors were retrofitted by another member on this forum. Unfortunately, I think he's moved on from his Pilot. Yes it looks amazing in the housing but even more importantly, it really improves the lighting in front of me.
Heres the thread where we did the final install on it.
https://www.piloteers.org/threads/how-i-spend-my-saturday-night.142665/#post-1449257
Nice ! I would love to retro fit a set Just don't know what proper parts to get for the switch over :)
A little searching will find more threads on some of the DIY retrofits. I thing that The Retrofit Source (dot com...) has the full parts list by now. For sure you'll want the projectors, the bulbs and ballasts, the surrounds of your choice, the adhesive for the plastic lens, and the wiring adapter or relay kit (depends on bulb choice and wattage). I'm not clear yet n the best way to manage the DRL/Main Beam hookup, as I'm pretty sure I'd want dual-beam projectors but maintain the existing DRL and flash-to-pass functions in the main beam bulbs.
I just had to do this on my 2015... I removed the intake to give myself a little more room and worked at it for a while contorting in various ways, but finally accomplished replacing the bulb without taking the bumper off. Didn't have to move the battery either. It's difficult but possible. Helps if you have arms like a Spider Monkey.
Not as bad as my 2014 Mazda 6. Gotta remove wheel liner and bust knuckles, cuss and deal with wiring that has zero play. You can only get two fingers in there—not even a thumb.
What really helps is a small stepladder. I am 5'9" and Pilot hood is tall enough that reaching in is hard But once a foot off the ground, I was actually able to reach in and change the foglight bulb! A head mounted flashlight is also a great help.
Look on DriveAccord forums, a member named DreaminAccord did a retrofit on his 7th Gen Accord when I did mine, I did not hook up the solenoid to activate the high beams as I have the eternal fear of parts failures and would rather not open up the headlights again, and I rarely get to use high beams where I live.
Anyway, he detailed the harness he created and what relays were needed to ensure that the solenoid wasn't receiving PWM power from the DRLs, which would cause the solenoid to fail in the projector, while maintaining the ability to have "quad" high beams. I'm pretty sure the solenoid still operated in a "flash to pass" scenario but that's full power and within their capability.
I haven't checked on TRS for a while, they may even have a harness suitable for the Honda system by now if you prefer premade wiring harnesses.
Just did this on my Niece’s Pilot. Removed top part of air intake on driver’s side and there’s a fastener toward the top of the windshield washer fluid reservoir on the passenger side that you can pop off that will then give you a little more wiggle room on the passenger side.
I wear a size 10 flight gloves and they’re tight and XL Latex gloves for reference on hand size. I didn’t have to remove anything else to get to them, but they wouldn’t budge except for the tiniest bit. After fighting with them for ten minutes I decided to unplug them, and it worked miracles. Suckers twisted out with not much effort at all.
So the trick is: UNPLUG THEM BEFORE ATTEMPTING TO TWIST THEM OUT!
Joined this group just to relate my experience after finding this thread trying to figure out what I was doing wrong. Thanks to Rocky for posting the relevant pages from the owner’s manual which is what caused me to decide to unplug them first. Hope it helps someone in the future.
Oh dam, ,my Mazda has burned through 5 or 6 headlight bulbs, drives me crazy. They can be changed without moving anything else but obviously it's very tight. The first time I had to change it I attempted it in an IKEA parking structure and it took me half an hour to get the clip to fasten on the bulb housing. My god I can remember it, when it finally caught on the hook after messing with it in bad light, mostly feeling my way, and just not being able to really tell how it goes together 'cause I couldn't get a good look at it even if there was light; it's just way back under the fender and you have to twist your hands around to get in there. It was a hallelujah moment when the clip just snapped tight, after trying over and over and over.
I'm pretty good at it now, but I think I've bent the little wire clips over time and maybe they vibrate and that's why they have gone bad again and again? I don't know but it's annoying.
I hope I never have to do it on the Pilot.
1 - 19 of 19 Posts
