1 - 2 of 2 Posts
I have an EX-L-RES with the single CD/DVD set-up. I've got a CD stuck in the player. I don't see a little mechanical eject hole and the manual says nothing about ejecting a stuck CD. I suspect the culprit will turn out to be the sticker label on the bootlegged Radiohead CD I got from my nephew. :rolleyes:
I can use the DVD player as a backup, so I'm not stuck for sound. Anyone have any idea of how to get the CD out so I don't have to go to the Honda dealer?
The best method that I can think of and probably the one the dealer would/should do is to take the radio out of the dash, remove the top of the radio housing and remove the adhesive. I'm guessing that the slot is too thin to get a pair of very thin needle nose pliers (even the ones where the nose doesn't widen near the pivot point) in there without damaging the gasket surrounding the slot. Better to play it safe on this one.
Chris
1 - 2 of 2 Posts
