Hi, the black wire is single back to the PCM, Grey is ground, the two whites are for heater circuit, it doesn't matter which way they go. However the schematic for a 2003 shows the following, the first wire combination will be the harness color followed by the corresponding O2 sensor with "universal color of black, grey, white, and white) With the 03 modelHelp. I had to replace the cat converter on an 03 ex, v6 one cat, the 02 sensor now shows fault when it was removed they cut the o2 wiring off at the snap plugs. Ok the blk and gray is no issue to connect wire to wire but the two whites do they have a certain connection to sensor I keep getting 141 fault code and need help with this. Is there a way to get the harness from the snap plug near the ac inlet all the way to the cat snap plug to insure I have proper connections? thanks
On the 3 way converter (upstream)
Black/White = White wires on the sensor that goes back to the PCM.
Black/Yellow = The other white wire, it is the 12v+ feed from fuse #6 driver side fuse box, so if you use a test light and get power that's it
Red/White = Black wire voltage from the PCM
Green/Yellow = Gray (another ground)
On the exhaust pipe (downstream)
Black/Yellow =Black on sensor wire again to fuse 6
Black/White = Black on sensor (orient these black wires in the same connector pin spot on the converter)
White = White back to the PCM
Light Green = Green/Yellow (another ground)
