1 - 20 of 375 Posts
Read down the page and it talks about installing software on the headunit to make this work. That might be a problem...
It's a good option if you want Carplay. Android Auto can be had for about $7.50 but either option will require root and "hacking" of some sort. This dongle device was intended for Android based aftermarket head units in my opinion but it still can work for us!
Sent from my XT1585 using Tapatalk
Discussion Starter · #16 ·
Hi everyone
I just got the device today (It took it a lot to get through customs). I had little time to play with it, but IT WORKS! at least the CarPlay part. I don't have an android device so I can not tell. I could not play a lot with it, so I'm not sure if everything works as it should.
As far as I've tested:
Music apps work and sound is great (Tune in radio, Podcast, Music, Amazon Music).
Maps works, but I had no voice coming from the speakers to get driving prompts.
I had not chance to test Siri or phone calls.
Getting it to work is fairy easy after you have the head unit rooted as shown here:
https://forum.xda-developers.com/android/general/guide-how-to-gain-root-shell-2016-honda-t3487644
After you had the unit rooted install the APK provided on the head unit and then plug the device in the left usb by the 12V socket and connect the iPhone to the usb on the device using a lighting cable. It doesn't seem to work with on the right one.
So far it seems I got CarPlay on my 2016 Pilot for 50$ instead of changing the head unit.
I hope this helps to somebody trying to avoid the hassle of swapping the head unit
How does the interface show up in your radio? Is it shown in the source menu as Apple Car Play? Do the Apple menus show up?
Discussion Starter · #19 ·
JonBaker00 You have to open the app you have to install (AutoPlay Box) and it connects to the activates CarPlay as shown on this video (If I have time I'll try to do one on the Pilot tonight).
The device shows up as a car on the iPhone CarPlay Settings so you can remove apps or change where they are displayed. (See screenshots from my phone attached)
I hope I've clarified some things for you.
Interesting. I’d be curious to see how the interface is different than the OEM deployment. Maybe make a video of you using it.
Nicely done!
1 - 20 of 375 Posts
