· Registered
Does anyone know if the cargo tray for the MDX and the cargo tray for the Pilot and the same size?
The reason I ask is that there is an aftermarket cargo tray (weathertech) in gray that I would like to get but it lists the same tray for the MDX and the Pilot. I know the MDX and Pilot are similar in size but are the cargo areas identical?
· Registered
I'm not sure but...
It most likely will fit, since the MDX and the Pilot are basically the same. Couldn't you send it back if it didn't work?
· Premium Member
they're darn close.....
You'll have to trim around the cargo hooks for the WeatherTech one, but it will work fine. The one thing that you do give up with the WT one is that the depressed area in the center is squared off, rather than the lip going straight to the edge.....which in turn makes it easy to trim to fit many applications.
