Recently changed the timing belt on car, works fine for a for about a month then all of a sudden while driving the car decide stall out towed car home had codes read and found cranck shaft position sensor code along with misfiring codes and random misfire code replaced sensor and. Car started ran about thirty min brought it home and turned off. When i went to restart car would not start. After trying again next day found evap and crankshaft code. But after stepping on gas while granking could hear some back fire and car would start and run normally after a bit but would have semi ruff idle
Can you post the exact codes you are getting? There are multiple codes for most of these sensors/functions that could point to different things being wrong.
