So my cat was stolen and I straight piped due to contained risk of being stolen again. I need to sell car and it needs its CAT to pass inspection.
See pic of my current exhaust set up. I'll probably need 1 to 2 O2 sensors as well. If i buy the cat below, obviously it has no where to bolt on. I will go to exhaust shop but what are they going to do. cut the ends off and weld it into current set-up. I just want to get rid of this car, and someone stealing my cat has made this a nightmare.
Product Font Cylinder Auto part Rim
Wheel Tire Automotive tire Motor vehicle Automotive fuel system
Psychedelic perspective. Is that your Pilot or your bimmer?
Font Circle Electric blue Pattern Darkness
If a Pilot, maybe slap on one of the cheapos here...
2006 EX-L w/RES in manly Taffeta White & no fender flares
I checked but didn't see where you're located. I think if you are going to be selling it to someone in CA or CO in the US, you'll need a CARB-compliant aftermarket cat or an OEM unit (I'm in Colorado, btw). Otherwise a generic unit should work pretty well. Before the rules change in 2021, I had a GM 4.3L V6 that needed a fresh converter, and used a generic that worked well.
