I have a P3400 Code and I was going to change out the engine oil pressure switch on my 2013 Honda Pilot. I was already to do so after watching videos on youtube but my oil pressure switch connector will not come loose. I am specifically referring to the upper right plastic piece on the diagram. I am afraid I am going to break it. Any tips on how this comes off?
the top right item Looks like a push tab connector if so try a small flat head from the bottom and pry up on the tab gently wiggling it at the same time pulling upward gently
The "pressure switch connector "? It's a typical standard auto connector. There is a clip that secures it to the switch. A small screwdriver or similar can pry the clip up and release the connector.
