Calling Canadian Pilots
37372 Views 153 Replies 127 Participants Last post by  Alcatraz_780
We have to have 1 or 2 in Great White North
Let us know what province you are from
Ontario Here
41 - 60 of 154 Posts
Hatfield Point NB here.
2011 Pilot EX-L, dark cherry pearl.
Toronto, ON 2011 EX-L Black on grey
Rural Ottawa
Rural (West) Ottawa
Barrie, Ontario.
Lotsa snow.
Great to own a Pilot.
Hanover, Manitoba. Loving my new to me Pilot!
18" vip status rims for sale with tires!!
Sorry guys i know this thread is for canadian piloteers, but i needed to find a buyer for these rims i have. I am in toronto area, 255/55/18s tires are pretty good..5 spoke with blk nd chrome...$1000 for the full set up.
5x120
msg me for details, sorry no pics..
from Banff Alberta 2011 4WD LX BLACK.just got it today.
Martensville, Saskatchewan here......Newbie! Just got it.
I recently located to Warman, just a stones throw away. Welcome!
Edmonton alberta
2007 ex-l pilot with airlift 1000 , and soon to have readylift leveling kit
Hey Dustman,
Weren't you originally in BC?
Hey Dustman,
No, Alberta actually, but barely. Lived in Lloydminster, a border city that is half in SK, half in AB. Now in Warman, just outside of Saskatoon.
Hey dustino8, where did you get your airlift 1000? I am thinking of that as well. What is your experience after the upgrade? I have just ordered a pair of SPC Rear Camber Kit (adjustable upper control arm) to make camber less negative for my next wheel alignment, just want make less inner edge tire wear in the future. But to make the rear suspension stronger, I am thinking of the airlift 1000 as well. Thanks!
Hey donx
To be honest, I can't recall where I bought it. May have been autopartsway.ca. My experience has been good with it. I initially installed it b/c I was towing regularly with the Pilot, and wanted to stiffen up the rear suspension. However, its helpful when you've got a large load of luggage, dogs, home improvement supplies, etc. in the cargo area, for leveling out the unit. I haven't had any issues with it, except last time I checked the air pressure in the bags and one was flat. I have to admit I hadn't checked them in several months, so it may just have a really slow leak. I'll have to check again soon to make sure its holding.
I drive around unloaded with 10-15 psi in them, and I can't notice a difference in the ride. Jack the psi up though, and you'll notice. Overall, been very happy with them. Just make sure that if you install yourself, buy a good bit for drilling the hole through the lower control arm. It will be expensive, but worth it. I think its a 7/8" hole that needs to be drilled. I cheaped out, thought I'd drill a small hole and then grind it out, but that didn't work so well. The metal on the control arm is very stout.
See less See more
Thanks a lot for the reply dustino8! They are quite useful. I used to take lots of passengers and their luggages for long road trips or fishing trips/skiing trips, etc. However, the load to my Pilot has been really reduced this year and most of the time I am the only one in the car, even even though I installed towing package 6 years ago, it was never used once for towing. I may buy a boat next spring, but it will stay in my cottage, so still no towing required... It seems like the airlift requires some maintenance to check and adjust the psi regularly, I may think of upgrading the maintenance-free Timbren rear suspension instead. Still not sure, I will check the suspension specs and tires next spring when I do the wheel alignment and decide what I want to use...
Brampton, ON
2012 Touring
Sent from my Autoguide iPhone app
markham, ontario
2011 Polished metallic EX-L RES
