1 - 18 of 18 Posts
Hello Guys,
My front passenger's caliper is getting really tight and it needs to be replaced.
My question is:
Can I use a caliper from different vehicles (makes/models) or it has to be specific for Honda Pilot?
If I am able to use calipers from different vehicles (makes/models) which one would go well with a Honda Pilot 2003?
Cheers,
Charles
Welcome @Charlesdanni ...best to get the right part for your Pilot. Not sure how things are in Canada but go to a reputable auto parts store, Rock Auto online, or the Honda dealer. Brakes are just too important to substitute calipers from different vehicles.
p.s.: what do you mean too tight?
Welcome to the forum.
I haven’t had to replace calipers yet, but if I did I would go with OEM or aftermarket which is made for the vehicle.
op may be referring to a pin being stuck in the Caliper
If you decide not to go OEM, I'd pick the Centrics or the Power Stops among these from Rockauto.com. Not only do they ship to Canada, unlike the often niggardly in shipping and occasionally untrustworthy in sourcing Amazon.com, but they have many paying options for Canadians, including direct bank transfers from the Big 5 here, so you don't get hosed on the exchange rate. What's more, take advantage of the PIloteers 5% discount.
2003 HONDA PILOT 3.5L V6 Caliper | RockAuto
5% Discount Code: 20CC2CFAD669A0
Expires: May 12, 2020
I'd also change them in pairs, but maybe that's just me.
On the other hand, as others mention, perhaps check if it's just stuck. You may be delighted to discover what wonders a little strategically applied lube might do. :)
Bout time your responding to threads ... you were on vacation or something :p
Banned
This is an odd question to me. Using a part from a different vehicle most likely wouldn't even work. Definitely get oem or good aftermarket for your exact vehicle. I'm looking at rear calipers on a 2004 and I'm currently looking for deals myself.
I've never considered using a part that wasn't from my vehicle. I mean at one point (like in my old Accords) there were vehicles that shared many components but sometimes had larger rotors and calipers, sway bars were stiffer, etc. (TLs or RLs). The only place I'd think to look is either an Odyssey or MDX but you'd likely be the person confirming whether they work or not.
Discussion Starter · #13 · (Edited)
Hello my fellow Piloteers,
So my problem with my caliper is the the cylinder is getting stuck on the same position, which is causing it to apply constant friction on my rotor.
do you think is easier to remove and replace the cylinder or the whole caliper?
regards,
Charles
Just replace the caliper, it's a quick process since you'll have to remove the caliper either way.
-Remove caliper
-clamp/install plug in brake line
-Remove cylinder
-Clean thoroughly
-Hone the bore
-Install new cylinder or cleaned up old cylinder with new seals
OR
-Remove caliper
-Install Caliper
You'll have to bleed either way.
Reactions: aggrex
Discussion Starter · #15 ·
-Remove caliper
-Remove cylinder
-Clean thoroughly
-Hone the bore
OR
-Remove caliper
-Install Caliper
Thanks for your reply.
how hard is it to proceed with the bleeding?
There are many videos on youtube about this, below is just one of them.
Remember, brakes are all the keep you from destruction while driving your 4000 lb SUV at 70 mph. If you aren't comfortable doing the repair, don't do it and let a professional handle it. A couple hundred dollars is a lot cheaper than a huge insurance bill.
And here I would be remiss if I didn't post a reminder of the oft-misunderstood brake bleeding sequence on a Pilot: Start with front driver's corner then go clockwise.
1 - 18 of 18 Posts
