The caliper slide pin is stuck on the rear drivers side. I called the dealership and they told me they don’t sell the bracket by itself and I would have to purchase the whole caliper with bracket for $250.
Does anyone know the OEM caliper bracket number and where I can order it? I emailed rockauto and a google search turned up some aftermarket brackets but I prefer OEM.
With the caliper slide pin stuck in the OEM bracket the Pilot ain't moving. Pick up an aftermarket caliper/bracket locally to get the Pilot driveable then continue the search for OEM.
If you buy a reman caliper with bracket, you will likely be getting an OEM. Beyond that, you are looking at salvage yards.
I'd just stick a quality rear complete caliper on there and go.
If you do go with non-OEM, paint the bracket with high-temp caliper paint prior to installation. Most of the remanufacturers send media blasted bare metal and it'll start to rust quickly.
