My Pilot came with the Bridgestone tires. I have over 25,000 miles on my car. How long are these tires supposed to last? Sorry I couldn't find the tire manual. :(
They look OK now, a little worn, but not enough to be replaced yet.
Also if you get Michelin Cross Terrains do they come in the same size as the Bridgestones? What size do I get?
thanks!
adjektiv said:
[ S N I P P E D ]
thanks!
Yes, the Michelin Cross Terrains come in the same size -- the (stock) size is P235/70R16 104S
Your tires should safely last around 40,000 miles (more or less, according to your driving habits and the tire pressure you keep in the tires - more aggressive driving and lower tire pressure normally means fewer miles before the tires wear out).
Be cautious of replacement tires, regardless of brand, because a tire with a longer tread life guarantee means that you are buying a tire manufactured with harder rubber (required to achieve the longer tread life). Longer wearing tires may not provide as 'soft' a ride as you might like with the Pilot.
Michelin Cross Terrain tires should be an excellent replacement tire.
JJ
